I purchased two Aer F120s from NZXT since I have no intake right now. I left the stock fans on the top and rear as came with the case for my build. I might not even have an issue with temps but just saying I don't have intakes sounds really bad and makes me feel like it's an issue...
The case has a panel mounted with thumbscrews. I thought the fans went between this panel and the front solid piece of the case. I was told they go on the other side of this panel... I am also unsure how these are even mounted? This panel has holes for 140mm and 120mm fans but how exactly are the fans mounted on this piece that comes out of the case?
I guess you just screw in on the opposite side of the panel from the fans? I have all the screws from the case and the instructions do indicate which ones go to fans... I guess I'm just not visualizing it.
