N Natrium Jul 10, 2019 42 1 35 Aug 1, 2019 #1 Ive been thinking about this so much lately. I bought a NZXT H500 and should you even get intake fans? I got two but i dont see where they are pulling in air from? The front panel doesnt have any small holes or anything, at least nothing i can see.
Solution anoori9000 Aug 1, 2019 Under the case and on the side of the case there are small ventilation holes for front intakes.
anoori9000 Distinguished Sep 28, 2013 1,749 8 20,815 Aug 1, 2019 Solution #2 Under the case and on the side of the case there are small ventilation holes for front intakes. Upvote 0 Downvote Solution
N Natrium Jul 10, 2019 42 1 35 Aug 1, 2019 #3 anoori9000 said: Under the case and on the side of the case there are small ventilation holes for front intakes. Click to expand... So intake fans do help? Upvote 0 Downvote
anoori9000 Distinguished Sep 28, 2013 1,749 8 20,815 Aug 1, 2019 #4 Natrium said: So intake fans do help? Click to expand... yes Upvote 0 Downvote
