[SOLVED] NZXT h510 BROKEN PINS HELP!!!
the little cable on the right of your photo is a front panel extension cable, if it's just the pins broken in that and the metal sockets in the other cable on the left don't look damaged, you'd be best getting something like this (it doesn't need to be this exact one):
https://www.ebay.co.uk/itm/362995155025?mkevt=1&mkcid=28&chn=ps
then you'll have to work out witch sockets the original wires go to on your broken cable and only use the relevant ones
