[SOLVED] NZXT H510 BROKEN PINS HELP!
Sometimes there are unused connections with respect to the harness.
The important part is that the connections you use (plug in) are correctly matched.
The motherboard's User Guide/Manual should indicate which connector to use and the required pin connections for powering on (no screwdriver) and to indicate disk activity via the HDD led.
Cable or wiring harness.
Connects motherboard and case front panel.
For example:
https://www.sevenforums.com/hardwar...front-panel-wire-harness-pin-out-diagram.html
Note: the above link is just for example purposes and may not match your build's requirements.
You will need to look at both your motherboard connector and the case connector.
Pins and assignments (pinouts) are key.
Connectors, pins, pin labels, and color codes must match.
Use the broken cable harness as a guide and look (google) for a matching harness. Double check everything before purchasing.
For example:
the case has a 6 pin and the mobo just needs 2 pin power and 2 single pin hdd led's
