[SOLVED] NZXT H510 Fans
Jake311202
83
Hi, i was wondering what size fans and how many the NZXT H510 case comes with, also if im buying 3 fans for the front of the case, what ones should i get and what size do they need to be?
Front: 2 x 120mm or 2 x 140mm fan
Top: 1 x 120mm (1 x 120mm Aer F120 Case Version included) or 1 x 140mm fan
Rear: 1 x 120mm fan (1 x 120mm Aer F120 Case Version included)
Fan Specs: Aer F120 (Case Version)
I would add two 140mm front intakes.
The NZXT 500 series cases are a negative pressure design. They were originally intended to just run with the supplied exhaust fans for best performance.
Look at the reviews that are out there. Front fans do not decrease cpu temps, rather they will increase the gpu temps.
When used as designed it's a great case that runs extremely quiet. I'm using a 120 AIO at the rear exhaust and a 140mm top exhaust. That's it.
My 3800x runs peaks at 74C max and the Asus ROG Strix 2070S runs at a chilly 54C.
Good case when used as intended.
