[SOLVED] NZXT H510i Airflow correct?????
Sep 7, 2020
Hi, so I have recently done my first ever build about ~2 weeks ago, and everything is running smooth, apart from the cooling? I have felt my case get a decently bit hot (~70ºC??) when playing games like CS:GO, so I decided to finally tackle this small problem, if you guys could help me out wether any of the fans are setup incorrectly? I know this case was meant to have a Negative Airflow, but I have no idea wether that is the case (no pun intended).
Extras:
Dust is starting to settle in and yes I will do a clean every month or so.
My cable management isn't the best and I know this, I plan on fixing that after I get this problem out of the way.
Yes, I know that my cooler is upside down, I'll fix that when I feel like it lol.
I planned on replacing both fans with RGB ones, but only one of them, fit as the CPU cable or whatever it was called, was not letting me put the fan all the way in.
Extras:
Negative pressure with only the stock fan configuration. That hybrid cooler completely changes it.
As for everything else:
-Dust is inevitable. If you've got a plan on when to tackle it, cool.
-Cooler isn't 'upside down'. What should be avoided is the pump being the highest point of the loop. If the pump isn't the highest point, you'll still end up having to rotate the radiator at some point.
-Radiator fans are backwards. Flip 'em around.
-Rear fan is also backwards.
Extras:
Okay, so I should just flip the fans but still have the radiator on the "outside" right?
