Hey guys,
I am looking for a solution on a short "issue" I am having with my new build. I build my first computer yesterday and for some reason when I only turn on my PSU the front 3 fans blink just once. Once that is done I press the power button and everything works perfectly fine.
I am wondering why is that happening, I have tried disconnecting and reconnecting all fans, along with using a different RGB port D-LED1/D-LED2. my build has a 4080 super which requires 3 PCI-E connections, for some reason my Corsair 850e only have 4 ports (2 for CPU and 2 for GPU), for now I have daisy chained the last PCI-E, is that what is causing this? I tried using only 2 PCI-E ports and the GPU did not turn on at all.
I am using all 4 sys-fan ports, one for the 3 way NZXT case fans in sys-fan 1 and the other 3 are being used by LL120 corsair fans. RBG for the NZXT case fans is in the top right RGB header, idk if it's D-LED 1 or 2, both ports show the blink. Being my first build, I am worried something my break (fry).
My Setup;
NZXT H6 FLOW RGB
AORUS B650 ELITE AX
AMD RYZEN 7 7800X3D
GIGABYTE 4080 SUPER WINDFORCE
TEAM T-FORCE 16x2 GB 6000MHZ
THERMALRIGHT PEERLESS ASSASSIN 120 ARGB
KRYONAUT THERMAL COMPOUND
CORSAIR RM850E
LL120 CORSAIR FANS
2X NOTCUA REDUX 140MM FANS (NOT CONNECTED, JUST THERE SCREWED IN FOR FUTURE)
My Setup;
NZXT H6 FLOW RGB
AORUS B650 ELITE AX
AMD RYZEN 7 7800X3D
CORSAIR RM850E
LL120 CORSAIR FANS
