NZXT - How to reduce dust building
Boeing100
Hi All
I built my own PC with a NZXT Phantom 530 about 8 months ago. Though I'm happy with everything , and all is working well, I have some serious dust building up inside the case.
I have sufficient ventilation for my needs (I do not OC, at least for now), and am not using the top mount in the case for additional fans / Liquid cooling radiator. The problem with this is that it's pretty much open air, there's only a "grill" protecting the inside of the PC to the outside world. Hence dust call travel into the case very easily, as the space is unobstructed by fans.
Do you know of a plastic / metal plate that I can buy to completely block the top part of the case from outside air? What would be my options, beyond actually installing extra fans which I don't need or want?
Many thanks!
