so i got this aio yesterday and i can hear very weird noise from the AIO and i have no clue what it is, it's very loud:
View: https://youtu.be/EwQK-mak7_c
sameI can't tell a diff. I hear normal airflow noise. Also, no bubbling noise.
Does the noise get louder when you increase the rad fans RPM?
I mean i never heard this sound before, when i stop the fans the sound is still there.But if you stop the fan(s), does noise still continue?
Since i could hear a faint bearing noise, which most likely comes from the pump itself. Could be fans too but without stopping fans and ruling out fan bearing issue, can't say for certain.
Also, it almost sounds like a coil whine, which MoBos (albeit rarely) can produce. Though coil whine is more apparent for the GPUs and PSUs.
If you put your ear directly to the PC, can you make sense where it exactly comes from? Might want to use the inner tube of toilet paper roll (or similar hollow cylindrical object) to better pinpoint the source of noise, when putting your ear to it.when i stop the fans the sound still is still there
Not many moving parts inside the PC to make noise. Fan/pump bearings, HDD, airflow noise and coil whine. That's it. Oh, vibration noise too (e.g HDD or fans vibrating and amplifying the vibrations all over the PC case).
If you put your ear directly to the PC, can you make sense where it exactly comes from? Might want to use the inner tube of toilet paper roll (or similar hollow cylindrical object) to better pinpoint the source of noise, when putting your ear to iti
Well i can hear it from the pump, i had GameMax ICEBURG-240 Black and it was very good aio very silent and i didnt hear anything but this makes me crazy, but sometimes when i restart the Pc the sound is gone..Not many moving parts inside the PC to make noise. Fan/pump bearings, HDD, airflow noise and coil whine. That's it. Oh, vibration noise too (e.g HDD or fans vibrating and amplifying the vibrations all over the PC case).
From the AIO pump, there are 2 noises it can make:Well i can hear it from the pump
Could be air trapped inside the pump. Since bearing noise would sound every time pump rotates (given the pump RPM is on that "sweet spot").but sometimes when i restart the Pc the sound is gone..
