Good day all,
So I'm a first time water cooler, but long time builder. I just fitted my X42 which arrived a few days ago, very happy with it apart from a seemingly strange problem. It will not power a Noctua Industrial PPC 2000 PWM 140mm fan that I installed instead of the stock one. Whereas if i connect the stock fan, it powers it completely fine.
The (Noctua) fan itself is fine, when its plugged into the fan header on the motherboard its works as it should. So i know its not a faulty fan. The problem lies when it is connected into the X42 radiator and pump system; when the PC is booted, the fan moves and inch then stops, never to move again. It looks physically like it is not getting enough power, and if i try to encourage the fan with a little push to start, it does nothing. It just stops again.
If I use the stock NZXT fan, it spins up perfectly and works normal. now, here is the strange part: if using the stock fan, and I then plug the added Noctua in to the second fan connector on the X42, it spins up also working fine! Not sure where to start with this problem, as mentioned this is my first time with a AIO cooler, this is new territory. Is this normal?
IN A NUTSHELL: The stock fan works on its own, in either fan port on the X42 perfectly. The Noctua does not work in any port if it is the only fan connected. The Noctua works only if the stock fan is present in one of the two fan ports.
Is this strange or is it my ignorance?
I would be grateful if someone with experience can give me a solution. Cheers chaps!
Regards,
6700K
Asus Z170I Pro Gaming
NZXT Kraken X42
EVGA 550 GS
Fractal Core 500
Regards,
6700K
NZXT Kraken X42
EVGA 550 GS
Fractal Core 500
