NZXT Kraken x61 temps and fan speeds question.
Noiz1212
59
So I just built a new system with the Kraken. And my temps are around 21C idle.
I tried the Aida 64 stress test and under 100% load it's around 42C
But this is too low for my fan speeds to go higher, so I wanted to test how cold I could get it, so I made a custom profile to go 100% just for testing and it was still 42C is that normal?
My cpu is Intel i7 6700k, no overclocking yet.
Are you 100% sure that that's the case? Can you try again using a custom profile with an unchanging 25% fan speed?
I would say that's unusual, but certainly not completely unexpected. Some cases/fans move air better than others, and it's possible that no matter the speed the temperature simply doesn't change.
I made a profile to keep it at 25% no matter the temp, and it stayed at like 42, but I ran the test a little longer and it went to like 44 and in another program to 46, I then turned on my 100% fan profile and saw it going down like 2 degrees in both program, so I guess it works, but I just think it's a very small diffrence, maybe it's hard to see diffrence in those low temps, I'll guess I see what happends after I've overclocked the 6700k.
Is that on the 100% profile?
A safe and expected heavy load temperature for the 6700k is 80c, and considering you are more than 20c under that number, I'd say it's a win (especially if you're not using 100% on the fans). If you were expecting lower temperatures, you could always go back and check your thermal paste to ensure you have optimal coverage - but in my opinion, your Kraken is performing great.
