NZXT Kraken x62 push and pull possible in Phanteks Eclipse P400s case?
d4v0
471
Hey all,
Trying to build a new PC and my current PC case is full tower this time I want to go mid tower and I really like Phanteks Eclipse p400s case with tempered glass. I know the kraken x62 fits in the case and I will mount it on the front but was just wondering will push and pull fit? Looked everywhere and couldn't find anyone that had the setup even on pcpartpicker. So hoping someone can tell me if it will work. Thank you in advance!
Yes, the X62 can be configured with Push/Pull fans mounted at the front intake of the P400S. See this setup:
Source: https://pcpartpicker.com/b/HwP323
I'm glad you received an answer to this question. I was just looking it up myself, I am doing something similar with nearly identical components. Hopefully you can answer a question I have, if you don't mind. What are all the fan sizes you are using? I see a total of 7 fans. ( 4 for the radiator, 2 above, 1 behind)
Hey sorry for the late replay but i eventually ended up going with Phanteks Evolve Tempered Glass one.
