Question NZXT Kraken X63 - Radiator Fan Question
Mar 20, 2020
I'm thinking about buying a Kraken X63 as well as a H510i case... I have 2 questions:
1. I noticed that the X63 doesn't come with the daisy chain connector for the radiator fans like the X62. Does this mean I need to plug the radiator fans into the Smart Device V2 that comes with the H510i case? If I do this how do these fans regulate based on the CPU temp... would it be through CAM. Would it be possible to get a splitter and connect both the radiator fans to the CPU Fan 1 header and connect the pump to the CPU Pump header.
2. Is CAM really as bad as people make it out to be?
