Hello and thank you for your time reading this
I just built a new system :
Motherboard: asus viii impact
Gpu: gtx 1070
ram: 16gb ddr4
ssd sandisk ultra II
psu: cooler master v550
case:nzxt manta
All went ok , but i ran to a problem.
I plugged in the fun hub to my motherboard and my cpu's cooler to my motherboard's cpu fan plugin. All my fans except my CPU's ran at a very high rpm even at idle. On my software i can control my cpu fan speed, but not the others. Can you suggest me where do i have to connect my hub properly to control my fan speeds? I read that you can control with this hub 1 fan's rpm and this fan will give signal to the other case fans , so one fan represents the other 2 but seems like i cant control none of the three right now. Did i plugged the cables wrong? I plugged the hub's molex directly to my psu. ( My case has 3 stock fans 1 exhaust and 2 intake).
Is there any solution to this problem?
Again thank you a lot for your time and I'm looking forward for your reply.
Sorry for my bad english
Gpu: gtx 1070
ram: 16gb ddr4
case:nzxt manta
