Hey good afternoon all. I have a questions and I'd really like some help! I have a brand new build, everything seems to be working great. When I first connected the aio pump and the radiator/fans to the motherboard, everything was working great. The cam software, provided by NZXT, would let me adjust the fan and aio pump to what I desired. Though, when I tried to make a new profile just for gaming, I set the aio pump and the fans to 100%, and I don't feel like they where at 100%, because I had an old version of the aio/radiator, and when it was at 100%, you knew it lol. This setup at 100% doesnt have the same effect as the old one. So I tried to adjust the settings in the Asus bio's to have all the fans running at turbo/100%. I l believe I messed something up when I did this because now the cam software wont detect the pump or the fans. And it doesnt show up in my computers device manager either. But the strange thing is, I believe it's working because I can monitor the temp through trhe cam software still, and it seems the pump is controlling the temps, because it's not going over 80 degrees c". Sorry for the ramble. I have no idead how to fix this. I've tried performing a clean install of windows 10 pro, i've cleared the bios and tried to reset them using the clearcmos button on the back of my motherboard. I've contacted both the Asus and NZXT and neither of them can figure it out. I did try to move the usb 2.0 mother header to a different 2.0 header, and the same thing happens. Though when I did unplug it, the fans kicked into higher gear from being completly silent. I have the AIO pump set up exactly as the NZXT manual tells you to. I'm wondering what the hell I did, and if it's something I didn't do, i'd like to know how to resolve it. Myabe the AIO cooler isn't compatabitle with my motherboard? Sorry if I didn''t post the question correctly or if I left something out. I really apperciate the help and feedback!
My set up is
Asus Maximus xi code motherboard
Intel i7 9700k CL processor
Corsair T180 case
EVGA 1070TI graphics card
Corsair veangence 3200 32gb (x2 16) ram
Samung 860 evo 2tb ssd
NZXT kraken x72 pump
windows 10 pro
Corsair rmx 850w Power supply
My set up is
Corsair T180 case
windows 10 pro
