NZXT Noctis 450 pwm controller issue.
millerjeremy1991
Hey guys, this is my first post so go easy on me 😉
Now I just picked up a shiny new Noctis 450 case with the PWM fan controller, plugged the 2 fans from my rad into the controller as well as the 4 preinstalled fans, and plugged the "PWM" wire into my "cpu_opt" header. Booted into windows and opened gigabyte's system information viewer(SIV) to calibrate my fan curve. It is reading my cpu fan (which is obviously my pump) but every other value is 0 but it seems like they are running at full speed all the time.
No matter what I do I cannot adjust the fan speed, I've tried speedfan and going into bios to see if I had a pwm/manual mode but no luck.
Before upgrading my case I just had a cheepo deepcool tesseract and with my radfans hooked up to a splitter(cpu_opt), exhaust fan(sys_fan1) and 2 intakes (sys_fan2, sys_fan3) everything ran fine using "SIV" or just letting the motherboard work its magic with PWM.
I'm at a complete loss right now, Any help would be greatly appreciated :)
System specs
CPU : Intel Core i5-4690K @ 4.7
CPU Cooler: Deepcool CAPTAIN 240
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150
Memory: 2 x G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 XMP enabled in dual channel
Storage: Samsung 850 EVO-Series 120GB SSD
Seagate Barracuda 1TB 3.5" 7200RPM
Video Card: MSI GeForce GTX 970 4GB
Case: NZXT Noctis 450 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified
The fan controller comes with a extension cable right? Where did you plug that in? Just to double check, the cable labelled 'extension' is it connected to the white socket on the fan controller?
I'm having the same problem. My controller is plugged into sys 2 pwm header and I plugged one of my pwm radiator fans into the pwm extension (white header on controller), I can control the fan speed of the radiator fan but the rest of the fans seem to stay on 100 %
