Nzxt noctis 450 rog led wont work
chriscookjnr
Its a fresh build im using the asus prime z270-k mother board and although the pc works great i cant seem to get the case led's to work ive found a 12v g r b cable coming from the case which i think may be what needs to be plugged in but i dont know wether its to the mother board or the psu any help would be much appriciated
S6BvF
Read the "Aura-Sync" section on your case's manual for further info,
link: https://sta3-nzxtcorporation.netdna-ssl.com/uploads/download/attachment/598/N450_ROG-manual-122216-ver3_-_Web.pdf
There are 2 ways to connect the LEDs:
1. By using the molex to 4-pin RGB adapter included with your case and connect it to your PSU. Doing so will light up LEDs in red color.
2. By plugging the RGB cable to Asus Aura RGB header on MoBo. Since your MoBo doesn't have Asus Aura RGB header, you're left with 1st choice.
