E eelee Reputable Apr 29, 2014 5 0 4,510 Apr 29, 2014 #1 Just bought a build and stupidly didnt check if the graphics card I'm getting could fit the case. Case Model : NZXT Phantom 410 Card : Sapphire Radeon R9 270X Toxic OC 2048MB Can anyone confirm that it can fit? :S
Solution jimthenagual Apr 29, 2014 It doesn't look like it will fit. See what some others say. From case website: max vga is 305mm That graphics card is 308mm
jimthenagual Splendid Apr 8, 2012 4,008 16 29,365 Apr 29, 2014 Solution #2 It doesn't look like it will fit. See what some others say. From case website: max vga is 305mm That graphics card is 308mm Upvote 0 Downvote Solution
E eelee Reputable Apr 29, 2014 5 0 4,510 Apr 29, 2014 #3 Thank-you for the quick reply, I doubt it will fit either. Can't confrim it on the NZXT web because the GPU isn't listed to check. but i think it may be about 3mm too big? :/ Upvote 0 Downvote
jimthenagual Splendid Apr 8, 2012 4,008 16 29,365 Apr 29, 2014 #4 Yes, that's how I am understanding it as well. The gpu will be just 3mm too long, and that is after removing a fan from the case to make more room. Upvote 0 Downvote
E eelee Reputable Apr 29, 2014 5 0 4,510 Apr 29, 2014 #5 Yeah, cheers for the help matey. Looks like your right, might have to send a swift email to ammend my order! again thanks! Upvote 0 Downvote
