NZXT Phantom 410 Questions
ThatOneThere
So I'm thinking about getting a new case when I upgrade my past build and I'm thinking about the NZXT Phantom 410 black with orange trim but I have a few questions about it that I can't find the answers for.
1. Do any of the fans it comes with have LED's? If they do what color are the lights?
2. Do the extension slots in the back pop out and back on if I accidentally pop out the wrong ones?
3. Are there any surprises or issues I should know about before I buy it?
4. How easy is the cable management? Is it something I could do in an hour? Half an hour? Two hours?
Thanks for the help and I might have a few more questions come up with more research.
1. Yes, one of the three fans comes with an LED. The red one comes with a blue led, and i don't know about the others.
2. The GPU slots in the back do not pop in and out. They are secured with a thumb screw and you can put them in and out as you please.
3. I haven't had any issues with mine.
4. Cable management is easy with this case. Both sides of the case come off, and the right side is entirely used for hiding your cables.
