M mogar1008 Honorable Jul 22, 2013 7 0 10,510 Jul 22, 2013 #1 I am new at building a computer so i was wondering what would be a good build for a nzxt phantom 820 case my budget is 1500 dollars but i could spend 2000 dollars.
Solution TheBigTroll Jul 23, 2013 there is no reason to spend that money on a huge case that you NEVER need a good build would be something like this http://pcpartpicker.com/p/1jJqi add the OS if need be. if you need a monitor and peripherals, i can recommend them to you
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Jul 23, 2013 Solution #2 there is no reason to spend that money on a huge case that you NEVER need a good build would be something like this http://pcpartpicker.com/p/1jJqi add the OS if need be. if you need a monitor and peripherals, i can recommend them to you Upvote 0 Downvote Solution
