I just finished building my PC then I noticed that the lights wasn't turning on. I opened my top panel and then I saw that there was no p led connector. Help ASAP
Uh.. P LED stands for Power LED... and check all your case fans which have LED lights if they are connected properly or not.. If you have connected all your fans to the motherboard as chassis fans then try removing 2-3 fans from the motherboard and try connecting them to the PSU... I assume that fans have molex connectors also... If not then check all your fans cables if they have been properly placed in the motherboard or not...
and the P LED is the power button's LED and nothing to do with the fan's LED...
Try cycling your LED's in the front I/O panel... Might be that the LEDs are off by default and you need to press the LED button to turn it on...
And one thing more, there should be a molex connector for your LED lights... When you first opened your case for building you must have seen a bundle of wires that are meant for the front I/O panel(P LED, Reset etc..), LED....In that bundle of wire there should be a molex connector that is for the LED lights... If you have not connected that molex connector to the PSU you will not see any LED lights for fan...
Oh and the link you posted has the solutions for the LED lights of your case... Take a deep look on the first point and if you are not being able to understand something you are free to ask here...
