NZXT Phantom - only NZXT fans?
follow the specs on the case website:
http://www.nzxt.com/product/detail/34-phantom
You might want to add a front fan. Fans do make a huge difference in performance. Even with a good case you probably need to add a fan or two. But you can find great fans for $10. Fan choice, company, doesn't matter. Only size.
You are buying one of the best cases on the market. I love that case. It's performance and reviews are off the chart. Good choice.
I decided to go for this.
However, I'm not sure whether I should use it as exhaust or intake. I know that I can simply install it the other way and it changes but which should I install it as?
It will be installed in the front of the PC. I checked and there's completely nothing behind it, no HDD or SSD.
