NZXT Phantom: Requesting help connecting two LED fans
Pat Moloney
7
The button for controlling the on/off switch only allows one LED connection at a time. Is there a way I could connect two LED fans to this switch? I'd be very grateful for step by step guides.
But where do I plug the LED cable that is attached to the fan? Both fans have this cable.
I'm saying there are two cables: One for connecting the fan to the fan controller and the other turning the LED's on/off with the button on the back.
All NZXT LED fans come with these two cables.
I know where the wire for the button is but I'm saying this one room for a connection. You can only plug one LED into it at a time.
I'm not sure what you mean. How do I connect each led separately?
I mean connect one led to the switch and note which wire to which (like a to a and b to b). Disconnect, connect the other one, note again. Same for the third. Then connect all 3 leds so that the a led wires are connected to the a wire of the switch and b led wires to the b wire of the switch.
