nzxt s 340 or nzxt phantom 410?
The phantom 410 gives you the option for a 280mm top mount instead of front mount (if that matters to you) and is an overall larger case. The 410 will also give you the option for an optical drive. Airflow and cable management should be fairly simple on either of them.
