NZXT S340 Liquid Cooling
Envit0
Hello guys. Had a quick question. I have just received my Maelstrom 240 AIO liquid cooling system. Was wondering, how did any of you mount a 240mm radiator so that the fans are for intake (front of case). Do you mount the radiator with long screws that go through case - fans and then to radiator?
there are two options:
push configuration - fans pushing the air though rad. In this case, you put the long screws through the case -> fans -> into rad.
pull configuration - fans pulling air through rad. in this case you attach the fans to rad with long screws and the rad to the case with short screws.
the pull option is more convenient. Much easier to clean - does not require to disassemble.
