NZXT water cooling CPU + GPU
TheLudaChris
11
Hi everyone, I'm working on designing my first water cooling build in my nzxt phantom 410.
I am looking at installing 1x 240mm rad in the top (I can't remember the thickness off the top of my head) and 1x 120mm radiator on the back mount. This will be to cool 1x i5 3570k and 1x 7970, my only concern is if this will be adequate or if I will have to mod the case for more cooling capacity.
Thanks.
Yes it is adequate, just make sure to plan your loop correctly. If you want to crossfire in the future, you'll need either 2 240's or 1 360 and a 240 for optimal temps.
