nzxt x62 kraken and LL120/140 Corsair fans compatibility?
sexchange
26
I'm thinking about purchasing an NZXT x62 KRAKEN cooler for my cpu. I was just wondering if Corsair fans and their RGBs would still work when plugged into the fan extention/controller that is plugged into the x62 kraken. The only reason I dont think that it will work is because they are different brands. Sorry I dont know much about fans and how their connectors work.
If you can help me, thanks.
The stock kraken x62 doesn't come with rgb aer fans. So only the cpu block has rgb.
The pump has 4 fan headers. So ur LL 140 fans would work with the kraken along with the speed control.
Also, the LL 140 has 2 cables, 1 for power and the other for rgb. The power pin is the 4 pin fan header which you can connect to the kraken.
For controlling rgb, u need corsair lightning node pro. Connect the rgb cables to the lightning node pro and that lightning node pro goes to a USB 2.0 header in the mobo. Then you can control ur rgb via lightning node pro with the corsair link software.
