[SOLVED] NZxt x73 install help
Pinster
4
Hey peeps
Recently got a new pc but I'm unsure about this NZxt cooler x73 , there are two cables one is a pump cable and the other is splitter cable for the 3 fans , do I plug the pump one into the aio header ? And the fans to cpu header ?. This is on Asus 570 tuf board .
Thanks in advance
According to their manual that looks like the correct way
Pump connector goes into the AIO_PUMP header (might just be named AIO or something like that but should get the idea across)
Fans to the CPU header
AHH right okie I see :) , just wanted to make sure as my older NZxt only had one cable to connect to the mobo but this has two :) .
Thanks for the help
Reactions: Furzumz
