OBS for gameplay recording.
pd2cwe
24
My system has 16gb RAM, i5 6600k and a highly overclocked gtx 980ti, outperforming a titan x minus the extra vram.
I want to use OBS to record gameplay, I've been messing around with the settings for a couple of days and I can't quite figure out the best settings for highest quality. Storage space isn't an issue and I don't mind taking a slight hit on the performance, if anyone could share some settings for high quality I'd appreciate it a lot.
Thanks.
You can try OBS since it's free:
https://obsproject.com/
And here's how to set it up for local recordings, start at the recommended crf 15, and lower the number for higher quality and higher file size recordings, or raise it for slightly lower quality and smaller file sizes.
https://obsproject.com/forum/resources/how-to-make-high-quality-local-recordings.16/
And to set it up for twitch:
http://help.twitch.tv/customer/portal/articles/1262922-open-broadcaster-software
If you have an Nvidia GPU, you can use that to reduce the load on your CPU:
To set it up for recordings:
1. go to settings
2. go to encoding
3. click the Nvidia NVENC button
4. Make sure Use CBR is turned on
5. Make sure Enable CBR Padding is turned off
6. Set your Max...
1. go to settings
2. go to encoding
6. Set your Max Bitrate (Kb/s) to your upload max upload speed. You'll want like 8000 or more though, this affects the visual quality of the video partly. (1mbps = 1000 kbps, www.speedtest.net)
7. go to Video and set the FPS to 60
8. Go to Advanced
9. Turn Use Multithreaded Optimizations on
10. Set NVENC Preset to High Quality (You can try the Lossless ones, those area bit higher quality but extremely huge, like 5GBs a min.)
11. Set Encoding Profile to Main
12. Turn Use CFR on.
To capture your game:
1. Right click in the white area of the Scenes: box and choose add scene, name it after the game you're gonna play.
2. Start the game you're gonna play.
3. right click in the Sources: box and choose Game Capture (for full screen games) or Window Capture (for windowed games whether borderless or not) or Monitor (to capture whatever is display one your monitor including your desktop/webbrowser/OBS)
4. Start recording.
To add a webcam:
1. Right click in the Sources: box and choose Video Capture Device.
2. Choose your webcam from the dropdown list at the top. Press Okay.
3. Click Preview Stream
4. Click the Video Capture in the sources list, go to Order and choose Move to Top.
5. Press the Edit Scene button
