obs stream lag with webcam??
The i7 will definitely improve all CPU related processing tasks. I would stick to GPU encoding and change as as experiment afterward to see where you get the best performance overall.
umm. wel i have cpu and gpu meter but when using the gpu encoding while streaming and gaming i usually get around 65% usage and around 65 degrees. cpu usage will be at around 70 as well. and when idle the temps and usage is very low. i honestly think its the cpu. im trying to get an i7 4790
ah. well then yes it rarely would hit 100. maybe 80 more that. im using stock fan cause cpu is not overclocked. i think if i get the i7 i can still encode on the gpu on obs but still bring the quality up. or maybe just switch to cpu encoding all in all once i get it
