OBS Stream Lags, FPS is fine
VileArtz
Commendable
Aug 28, 2016
8
I started streaming and when I record the quality/fps is fine, when I play the fps doesn't drop in-game but if I start streaming the video which is played on YouTube/Twitch is laggy and quality decreases.
My pc is a i5 6600k with a 750ti and 8gb ram
I stream at 720p/60fps with 2500kbps and my upload speed is ~90mbps
So recording is fine, but when I stream the video which my viewers see is lagging.
I use OBS btw.
Reactions: KillerMonk
Follow this video, it will help you find out what you need to change in the software, its a normal thing that happened to me as well, your PC is fine, just follow the video and your stream and recording wont lag, however you should expect some FPS drops on some games, there is nothing you can do about this, after about 10 mins of streaming or recording your things will balance, your stream wont lag and so will your game, so it just takes some patience, so far I have not found a better solution, so this is the one I use right now.
https://www.youtube.com/watch?v=MXVD3SB5Pw8
I use OBS btw.
View: https://www.youtube.com/watch?v=yCk0E2eIR0o&t=1s
Check this out! Thank me later
