OBS Stream Quality low for my good settings on obs?
HyperS
123
idk if this is in wrong category, but i cant find a streaming category.
Hey guys! im starting to stream a bit right? but i feel my quality is stupid bad, in comparison to someone like Summit1G. We have same obs settings, but my stream looks really bad
For an example, in the twitch clip i linked, u can barely see my crosshair, where as on summits stream. u can see it very "clearly"
BTW, I never drop frames on obs. as internet is 200/200 and my specs are:
i7-4790k oc to 4.5
EVGA 980ti oc +210 core. +300 memory
16gb ram
so i dont see my pc as the problem for the quality, but u guys tell me
OBS Settings:
https://gyazo.com/361ceab836567644b2fb705618c5cc6a
https://gyazo.com/b39b6f6b4dbaedf3d271d7c19d79e9f3
Clip From Stream:
https://clips.twitch.tv/AliveEmpathicRaccoonCurseLit
Clip From Summit1G's Stream
https://clips.twitch.tv/ProductiveRudeBeefDancingBanana
Can u guys tell me why my quality is way lower. or what i can do to fix it, and make it better? Thanks
Hyper
You are not partnered with twitch thats way. After you've gathered enough followers and viewers you might be able to start a partnership with twitch, that means you can use higher bitrate than 3500 which is currently the cap for non partnered users. Also when partenered, twitch re-encodes your videos, that means viewers will be able to select video quality from the options so you can go easily stream at 1080p / 60fps with really good bitrate and viewers with slower internet can just drop down the resolution for themselves.
Oh ty. how many followers do i need for partnership for twitch?
