[SOLVED] OBS Studio and GPU Issue
QueenAqua
Commendable
Jul 29, 2016
4
Okay I've tried all manner of adjustment but I can't seem to find an answer to this. I am running an Athlon quad core 860K with 32gb Corsair ram and using Nvidia GTX970 gpu.
When I am running OBS along with my game, my normal addons (chatty, streamlabs chatbot, pretzelrocks, etc), between minutes 2 and 15 of my stream, both of my monitors will flash black. When this happens, my stream is ended and to my viewers, I appear to be offline. However OBS continues as if nothing happened, and I must manually end my stream to restart it. The same problem then continues.
I have uninstalled and reinstalled OBS, I have done a Revo uninstall, I have tried SLOBS (Same issue replicated), I have done a driver wipe and safe mode reinstall, I have lowered and raised OBS settings and game settings. I'm not able to figure out what is going on. Help would be absolutely amazing. I've attached my most recent OBS crash log. I've had 11 of them today, this was during a test stream and happened at minute 2:55 of my stream. All test logs have identical information.
Prior to about November 1st, this issue never occurred. I made it through many streams of a full game. Nvidia released a driver update on 10/18/18. Any help would be greatly appreciated. Thank you.
LOG- is very long!!!!
17:46:23.090: CPU Name: AMD Athlon(tm) X4 860K Quad Core Processor
17:46:23.090: CPU Speed: 3700MHz
17:46:23.090: Physical Cores: 2, Logical Cores: 4
17:46:23.091: Physical Memory: 32707MB Total, 29798MB Free
17:46:23.091: Windows Version: 10.0 Build 17134 (revision: 376; 64-bit)
17:46:23.091: Running as administrator: false
17:46:23.091: Aero is Enabled (Aero is always on for windows 8 and above)
17:46:23.091: Windows 10 Gaming Features:
17:46:23.091: Game Bar: Off
17:46:23.091: Game DVR: Off
17:46:23.091: Game DVR Background Recording: Off
17:46:23.095: Sec. Software Status:
17:46:23.097: Windows Defender Antivirus: enabled (AV)
17:46:23.098: Windows Firewall: enabled (FW)
17:46:23.098: Windows Defender Antivirus: enabled (ASW)
17:46:23.098: Browser Hardware Acceleration: true
17:46:23.098: Portable mode: false
17:46:23.327: OBS 22.0.2 (64-bit, windows)
17:46:23.327: ---------------------------------
17:46:23.328: ---------------------------------
17:46:23.328: audio settings reset:
17:46:23.328: samples per sec: 44100
17:46:23.328: speakers: 2
17:46:23.330: ---------------------------------
17:46:23.330: Initializing D3D11...
17:46:23.330: Available Video Adapters:
17:46:23.332: Adapter 1: NVIDIA GeForce GTX 970
17:46:23.332: Dedicated VRAM: 4239917056
17:46:23.332: Shared VRAM: 4263223296
17:46:23.332: output 1: pos={0, 0}, size={1920, 1080}, attached=true
17:46:23.332: output 2: pos={1920, 0}, size={1440, 900}, attached=true
17:46:23.335: Loading up D3D11 on adapter NVIDIA GeForce GTX 970 (0)
17:46:23.437: D3D11 loaded successfully, feature level used: 45056
17:46:24.738: ---------------------------------
17:46:24.738: video settings reset:
17:46:24.738: base resolution: 1920x1080
17:46:24.738: output resolution: 1280x720
17:46:24.738: downscale filter: Bilinear
17:46:24.738: fps: 30/1
17:46:24.738: format: NV12
17:46:24.738: YUV mode: 601/Partial
17:46:24.741: Audio monitoring device:
17:46:24.741: name: Default
17:46:24.741: id: default
17:46:24.741: ---------------------------------
17:46:24.743: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
17:46:24.745: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
17:46:24.820: [AMF] AMF Test failed due to one or more errors.
17:46:24.820: Failed to initialize module 'enc-amf.dll'
17:46:24.850: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
17:46:24.851: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
17:46:24.851: (127)
17:46:24.851: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
17:46:24.854: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
17:46:24.858: [obs-browser]: Version 2.1.5
17:46:24.868: NVENC supported
17:46:24.971: VLC found, VLC video source enabled
17:46:24.978: No blackmagic support
17:46:24.983: ---------------------------------
17:46:24.983: Loaded Modules:
17:46:24.983: win-wasapi.dll
17:46:24.983: win-mf.dll
17:46:24.983: win-dshow.dll
17:46:24.983: win-decklink.dll
17:46:24.983: win-capture.dll
17:46:24.983: vlc-video.dll
17:46:24.983: text-freetype2.dll
17:46:24.983: rtmp-services.dll
17:46:24.983: obs-x264.dll
17:46:24.983: obs-vst.dll
17:46:24.983: obs-transitions.dll
17:46:24.983: obs-text.dll
17:46:24.983: obs-qsv11.dll
17:46:24.983: obs-outputs.dll
17:46:24.984: obs-filters.dll
17:46:24.984: obs-ffmpeg.dll
17:46:24.984: obs-browser.dll
17:46:24.984: image-source.dll
17:46:24.984: frontend-tools.dll
17:46:24.984: enc-amf.dll
17:46:24.984: coreaudio-encoder.dll
17:46:24.984: ---------------------------------
17:46:24.984: ==== Startup complete ===============================================
17:46:24.990: All scene data cleared
17:46:24.990: ------------------------------------------------
17:46:25.041: WASAPI: Device 'VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)' initialized
17:46:25.066: [Media Source 'ES1']: settings:
17:46:25.066: input: C:/Users/Queen Aqua/Desktop/Streaming/Images/Overlays/eda19289-6bf8-40e2-99c4-368d9f61b328/Ending Soon.webm
17:46:25.066: input_format: (null)
17:46:25.066: speed: 100
17:46:25.066: is_looping: yes
17:46:25.066: is_hw_decoding: yes
17:46:25.066: is_clear_on_media_end: yes
17:46:25.066: restart_on_activate: yes
17:46:25.066: close_when_inactive: no
17:46:25.071: [Media Source 'SS1']: settings:
17:46:25.071: input: C:/Users/Queen Aqua/Desktop/Streaming/Images/Overlays/eda19289-6bf8-40e2-99c4-368d9f61b328/Starting Soon.webm
17:46:25.071: input_format: (null)
17:46:25.071: speed: 100
17:46:25.071: is_looping: yes
17:46:25.071: is_hw_decoding: yes
17:46:25.071: is_clear_on_media_end: yes
17:46:25.071: restart_on_activate: yes
17:46:25.071: close_when_inactive: no
17:46:25.115: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
17:46:25.146: ---------------------------------
17:46:25.146: [DShow Device: 'Webcam'] settings updated:
17:46:25.146: video device: Logitech HD Webcam C270
17:46:25.146: video path: \\?\usb#vid_046d&pid_0825&mi_00#6&1b7135e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
17:46:25.146: resolution: 640x480
17:46:25.146: fps: 30.00 (interval: 333333)
17:46:25.146: format: I420
17:46:26.479: Switched to scene 'In Game'
17:46:26.479: ------------------------------------------------
17:46:26.479: Loaded scenes:
17:46:26.479: - scene 'Starting Soon':
17:46:26.479: - source: 'SS1' (ffmpeg_source)
17:46:26.479: - scene 'In Game':
17:46:26.481: - source: 'Game Capture' (game_capture)
17:46:26.481: - source: 'Current Track Playing' (text_gdiplus)
17:46:26.481: - filter: 'Scroll' (scroll_filter)
17:46:26.481: - source: 'Webcam' (dshow_input)
17:46:26.481: - source: 'Overlay' (browser_source)
17:46:26.481: - scene 'Ending Soon':
17:46:26.481: - source: 'ES1' (ffmpeg_source)
17:46:26.481: ------------------------------------------------
17:46:26.681: CalculateFileHash: Failed to open file 'C:\Users\Queen Aqua\AppData\Roaming\obs-studio\updates\whatsnew.json':
17:46:30.112: obs-browser: TypeError: Cannot read property 'variations' of undefined (source: https://streamelements.com/scripts/vendor-7d4cec3d2d.js:360)
17:47:23.003: Settings changed (outputs)
17:47:23.003: ------------------------------------------------
17:48:57.943: [game-capture: 'Game Capture'] attempting to hook fullscreen process: grimrock2.exe
17:48:57.949: [game-capture: 'Game Capture'] using helper (compatibility hook)
17:48:57.953: [game-capture: 'Game Capture'] hook not loaded yet, retrying..
17:49:00.974: [game-capture: 'Game Capture'] attempting to hook fullscreen process: grimrock2.exe
17:49:01.154: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
17:49:01.174: [game-capture: 'Game Capture'] shared texture capture successful
17:49:05.109: [game-capture: 'Game Capture'] Hooked DXGI
17:49:09.428: [game-capture: 'Game Capture'] capture window no longer exists, terminating capture
17:49:09.431: [game-capture: 'Game Capture'] capture stopped
17:49:31.210: [game-capture: 'Game Capture'] attempting to hook process: grimrock2.exe
17:49:31.243: [game-capture: 'Game Capture'] shared texture capture successful
17:50:29.353: ---------------------------------
17:50:29.353: [x264 encoder: 'streaming_h264'] preset: veryfast
17:50:29.353: [x264 encoder: 'streaming_h264'] profile: main
17:50:29.353: [x264 encoder: 'streaming_h264'] settings:
17:50:29.353: rate_control: CBR
17:50:29.353: bitrate: 2500
17:50:29.353: buffer size: 2500
17:50:29.353: crf: 0
17:50:29.353: fps_num: 30
17:50:29.353: fps_den: 1
17:50:29.353: width: 1280
17:50:29.353: height: 720
17:50:29.353: keyint: 250
17:50:29.353:
17:50:29.366: ---------------------------------
17:50:29.367: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
17:50:29.367:
17:50:29.370: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-iad.twitch.tv/app...
17:50:29.412: [rtmp stream: 'adv_stream'] Interface: Intel(R) I211 Gigabit Network Connection (ethernet, 1000 mbps)
17:50:30.015: [rtmp stream: 'adv_stream'] Connection to rtmp://live-iad.twitch.tv/app successful
17:50:30.019: ==== Streaming Start ===============================================
17:53:45.785: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
17:53:45.809: [game-capture: 'Game Capture'] shared texture capture successful
17:55:44.935: [rtmp stream: 'adv_stream'] User stopped the stream
17:55:44.935: Output 'adv_stream': stopping
17:55:44.935: Output 'adv_stream': Total frames output: 8881
17:55:44.935: Output 'adv_stream': Total drawn frames: 9198 (9467 attempted)
17:55:44.935: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 269 (2.8%)
17:55:44.936: Video stopped, number of skipped frames due to encoding lag: 5518/9443 (58.4%)
17:55:44.978: warning: 2 frames left in the queue on closing
17:55:44.993: ==== Streaming Stop ================================================
17:55:56.617: Settings changed (outputs)
17:55:56.617: ------------------------------------------------
17:56:00.555: ---------------------------------
17:56:00.555: [NVENC encoder: 'streaming_h264'] settings:
17:56:00.555: rate_control: CBR
17:56:00.555: bitrate: 2500
17:56:00.555: cqp: 0
17:56:00.555: keyint: 250
17:56:00.555: preset: default
17:56:00.555: profile: main
17:56:00.555: level: auto
17:56:00.555: width: 1280
17:56:00.555: height: 720
17:56:00.555: 2-pass: true
17:56:00.555: b-frames: 2
17:56:00.555: GPU: 0
17:56:00.555:
17:56:01.181: ---------------------------------
17:56:01.182: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
17:56:01.182:
17:56:01.185: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-iad.twitch.tv/app...
17:56:01.212: [rtmp stream: 'adv_stream'] Interface: Intel(R) I211 Gigabit Network Connection (ethernet, 1000 mbps)
17:56:01.790: [rtmp stream: 'adv_stream'] Connection to rtmp://live-iad.twitch.tv/app successful
17:56:01.799: ==== Streaming Start ===============================================
17:56:10.419: [game-capture: 'Game Capture'] ----------------- d3d9 capture freed -----------------
17:56:11.489: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
17:56:11.524: [game-capture: 'Game Capture'] shared texture capture successful
17:56:25.803: [game-capture: 'Game Capture'] ----------------- d3d9 capture freed -----------------
17:56:28.298: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
17:56:28.321: [game-capture: 'Game Capture'] shared texture capture successful
17:57:54.812: Device Remove/Reset! Rebuilding all assets...
17:57:55.215: [game-capture: 'Game Capture'] ----------------- d3d9 capture freed -----------------
17:57:56.100: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
17:57:56.104: Failed to rebuild shared texture:
17:57:56.110: Failed to rebuild shared texture:
17:57:56.232: [game-capture: 'Game Capture'] shared texture capture successful
17:57:56.443: error: EncodePicture failed!: generic error (20)
17:57:56.444: [NVENC encoder: 'streaming_h264'] nvenc_encode: Error encoding: Unknown error occurred
17:57:56.444: Video stopped, number of skipped frames due to encoding lag: 27/3350 (0.8%)
17:57:58.147: Error encoding with encoder 'streaming_h264'
17:58:02.044: [game-capture: 'Game Capture'] ----------------- d3d9 capture freed -----------------
17:58:03.106: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
17:58:03.148: [game-capture: 'Game Capture'] shared texture capture successful
17:59:05.762: [rtmp stream: 'adv_stream'] User stopped the stream
17:59:05.762: Output 'adv_stream': stopping
17:59:05.762: Output 'adv_stream': Total frames output: 3340
17:59:05.762: Output 'adv_stream': Total drawn frames: 5169 (5537 attempted)
17:59:05.762: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 368 (6.6%)
17:59:05.763: warning: 2 frames left in the queue on closing
17:59:05.782: ==== Streaming Stop ================================================
17:59:17.194: ==== Shutting down ==================================================
17:59:17.225: Switched to scene '(null)'
17:59:17.234: [game-capture: 'Game Capture'] capture stopped
17:59:17.344: WASAPI: Device 'VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)' Terminated
17:59:17.352: All scene data cleared
17:59:17.352: ------------------------------------------------
17:59:17.606: Freeing OBS context data
17:59:17.722: [Scripting] Total detached callbacks: 0
17:59:17.789: == Profiler Results =============================
17:59:17.789: run_program_init: 4462.78 ms
17:59:17.789: ┣OBSApp::AppInit: 42.222 ms
17:59:17.789: ┃ ┗OBSApp::InitLocale: 4.229 ms
17:59:17.789: ┗OBSApp::OBSInit: 4393.55 ms
17:59:17.789: ┣obs_startup: 8.715 ms
17:59:17.789: ┗OBSBasic::OBSInit: 3320.31 ms
17:59:17.789: ┣OBSBasic::InitBasicConfig: 0.899 ms
17:59:17.789: ┣OBSBasic::ResetAudio: 0.368 ms
17:59:17.789: ┣OBSBasic::ResetVideo: 1411.86 ms
17:59:17.789: ┣OBSBasic::InitOBSCallbacks: 0.01 ms
17:59:17.789: ┣OBSBasic::InitHotkeys: 0.075 ms
17:59:17.789: ┣obs_load_all_modules: 242.398 ms
17:59:17.789: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.72 ms
17:59:17.789: ┃ ┣obs_init_module(enc-amf.dll): 73.3 ms
17:59:17.789: ┃ ┣obs_init_module(frontend-tools.dll): 9.463 ms
17:59:17.789: ┃ ┣obs_init_module(image-source.dll): 0.009 ms
17:59:17.789: ┃ ┣obs_init_module(obs-browser.dll): 0.34 ms
17:59:17.789: ┃ ┣obs_init_module(obs-ffmpeg.dll): 2.827 ms
17:59:17.789: ┃ ┃ ┗nvenc_check: 2.707 ms
17:59:17.789: ┃ ┣obs_init_module(obs-filters.dll): 0.034 ms
17:59:17.789: ┃ ┣obs_init_module(obs-outputs.dll): 0.02 ms
17:59:17.789: ┃ ┣obs_init_module(obs-qsv11.dll): 77.654 ms
17:59:17.789: ┃ ┣obs_init_module(obs-text.dll): 0.649 ms
17:59:17.789: ┃ ┣obs_init_module(obs-transitions.dll): 0.013 ms
17:59:17.789: ┃ ┣obs_init_module(obs-vst.dll): 0.005 ms
17:59:17.789: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
17:59:17.789: ┃ ┣obs_init_module(rtmp-services.dll): 3.319 ms
17:59:17.790: ┃ ┣obs_init_module(text-freetype2.dll): 0.08 ms
17:59:17.790: ┃ ┣obs_init_module(vlc-video.dll): 2.533 ms
17:59:17.790: ┃ ┣obs_init_module(win-capture.dll): 0.526 ms
17:59:17.790: ┃ ┣obs_init_module(win-decklink.dll): 4.24 ms
17:59:17.790: ┃ ┣obs_init_module(win-dshow.dll): 1.76 ms
17:59:17.790: ┃ ┣obs_init_module(win-mf.dll): 0.001 ms
17:59:17.790: ┃ ┣obs_init_module(win-wasapi.dll): 0.014 ms
17:59:17.790: ┃ ┗reset_win32_symbol_paths: 0.409 ms
17:59:17.790: ┣OBSBasic::ResetOutputs: 0.859 ms
17:59:17.790: ┣OBSBasic::CreateHotkeys: 0.058 ms
17:59:17.790: ┣OBSBasic::InitService: 1.935 ms
17:59:17.790: ┣OBSBasic::InitPrimitives: 0.473 ms
17:59:17.790: ┗OBSBasic::Load: 1531.8 ms
17:59:17.790: obs_hotkey_thread(25 ms): min=0.002 ms, median=0.008 ms, max=1095.06 ms, 99th percentile=1.885 ms, 99.9224% below 25 ms
17:59:17.791: audio_thread(Audio): min=0 ms, median=0.81 ms, max=3088.87 ms, 99th percentile=25.936 ms
17:59:17.791: ┗receive_audio: min=0.003 ms, median=0.923 ms, max=798.755 ms, 99th percentile=21.626 ms, 0.805209 calls per parent call
17:59:17.791: ┣buffer_audio: min=0.001 ms, median=0.003 ms, max=21.095 ms, 99th percentile=0.041 ms
17:59:17.791: ┗do_encode: min=0.029 ms, median=0.907 ms, max=798.745 ms, 99th percentile=21.302 ms
17:59:17.791: ┣encode(Track1): min=0.061 ms, median=0.781 ms, max=113.219 ms, 99th percentile=18.706 ms, 0.631302 calls per parent call
17:59:17.791: ┗encode(Track1): min=0.021 ms, median=0.827 ms, max=798.713 ms, 99th percentile=20.505 ms, 0.368698 calls per parent call
17:59:17.791: obs_graphics_thread(33.3333 ms): min=0.143 ms, median=4.159 ms, max=3103.14 ms, 99th percentile=39.342 ms, 98.3772% below 33.333 ms
17:59:17.791: ┣tick_sources: min=0.004 ms, median=0.042 ms, max=1433.09 ms, 99th percentile=3.028 ms
17:59:17.791: ┣output_frame: min=0.134 ms, median=2.572 ms, max=3099.48 ms, 99th percentile=33.696 ms
17:59:17.791: ┃ ┣gs_context(video->graphics): min=0.133 ms, median=1.939 ms, max=3099.48 ms, 99th percentile=31.947 ms
17:59:17.791: ┃ ┃ ┣render_video: min=0.013 ms, median=0.553 ms, max=3098.47 ms, 99th percentile=29.135 ms
17:59:17.792: ┃ ┃ ┃ ┣render_main_texture: min=0.008 ms, median=0.452 ms, max=3098.46 ms, 99th percentile=27.231 ms
17:59:17.792: ┃ ┃ ┃ ┣render_output_texture: min=0.001 ms, median=0.024 ms, max=62.599 ms, 99th percentile=14.998 ms, 0.55193 calls per parent call
17:59:17.792: ┃ ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.018 ms, max=105.915 ms, 99th percentile=8.228 ms, 0.55193 calls per parent call
17:59:17.792: ┃ ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.005 ms, max=97.255 ms, 99th percentile=5.944 ms, 0.55193 calls per parent call
17:59:17.792: ┃ ┃ ┣gs_flush: min=0.006 ms, median=0.331 ms, max=346.325 ms, 99th percentile=21.913 ms
17:59:17.792: ┃ ┃ ┗download_frame: min=0 ms, median=0.004 ms, max=2770.03 ms, 99th percentile=9.736 ms, 0.55193 calls per parent call
17:59:17.792: ┃ ┗output_video_data: min=0.001 ms, median=0.596 ms, max=64.262 ms, 99th percentile=19.22 ms, 0.551529 calls per parent call
17:59:17.792: ┗render_displays: min=0.001 ms, median=0.582 ms, max=1448.3 ms, 99th percentile=17.707 ms
17:59:17.792: OBSBasic::ResetOutputs: min=0.488 ms, median=0 ms, max=3.88 ms, 99th percentile=3.88 ms
17:59:17.792: video_thread(video): min=1.124 ms, median=2.568 ms, max=13642.6 ms, 99th percentile=536.181 ms
17:59:17.792: ┗receive_video: min=1.064 ms, median=2.731 ms, max=2192.55 ms, 99th percentile=215.647 ms, 1.80096 calls per parent call
17:59:17.792: ┗do_encode: min=1.063 ms, median=2.73 ms, max=2192.54 ms, 99th percentile=215.647 ms
17:59:17.792: ┣encode(streaming_h264): min=1.007 ms, median=2.236 ms, max=2192.41 ms, 99th percentile=260.483 ms, 0.73808 calls per parent call
17:59:17.792: ┗encode(streaming_h264): min=1.45 ms, median=3.13 ms, max=146.769 ms, 99th percentile=24.896 ms, 0.26192 calls per parent call
17:59:17.792: =================================================
17:59:17.792: == Profiler Time Between Calls ==================
17:59:17.793: obs_hotkey_thread(25 ms): min=24.044 ms, median=26.144 ms, max=2080.69 ms, 22.9483% within ±2% of 25 ms (1.97897% lower, 75.0728% higher)
17:59:17.793: obs_graphics_thread(33.3333 ms): min=0.755 ms, median=33.333 ms, max=3103.37 ms, 55.7957% within ±2% of 33.333 ms (22.5601% lower, 21.6442% higher)
17:59:17.793: =================================================
17:59:18.944: Number of memory leaks: 0
You can try to re-install video drivers and run OBS Studio in portable mode in different folder: https://obsproject.com/forum/resources/obs-and-obs-studio-portable-mode-on-windows.359/
haug_peyton
Proper
Sep 25, 2018
95
