OC not saving after turn off and turn on again
Oct 26, 2018
Hello Guys
I have always used the ryzen 3 1200 in overclocking at 3.8ghz and ddr4 at 3000mhz. all working fine on windows, no crashes, no blue screen, all perfect in extreme gaming at 144fps.
A few days ago, I noticed that when I turn ON the pc, bios detects some problem and the cpu overclock is zeroed, clear, facing the 3.1ghz stock.
After I set the overclock again on bios, windows boots and everything works correctly with the overclock set, but once I turn off the pc and turn it on again, I have the same problem. The motherboard returns the configuration stock to 3.1ghz in the cpu.
I saw that several people have equal problems and even on motherboards of other brands.
This problem began to give in bios f22. I upgraded to f23 but the problem continues.
The problem happens in the same way if the overclock starts from 3.1ghz to 3.2ghz or starting from 3.1ghz to 3.8ghz.
I tried clear cmos without success
Is there any further procedure to be done? Is it a problem known to you?
Thank you.
Product Name: GA-AB350M-D3H (1.0)
BIOS Ver: f23
Brand: GIGABYTE
Model: AORUS Radeon™ RX580 8G (1.0/1.1)
Model: ryzen 3 1200
Operating System: Win 10 64-bit
Brand: Kingston
Power Supply: corsair 600w
