Hey guys. I got a new HSF (VANTEC AeroFlow VA4-C7040) today and when I first installed it my CPU temp dropped from 53 to 41 degrees. I was extreemly pleased with the results so I decided to OC my 1.2Mhz TB. I read some reviews and knocked it up to 1.4Mhz (10x140mhz) and my temp only went up to 43 degrees. I ran some tests and it was stable. Then I decided to raise it to 1.6Mhz (11x145mhz). It wasn't stable at this speed so I brought it back down 1.4mhz and left for a while, figuring it would be okay since I already tested this setting. I came back to a BSOD. The temp broke 60 degrees and set off the thermal protection on my mobo. I then reclocked my cpu to the factory default but it was still getting hot at around 55-60 degrees. I took off the HSF and cleaned the cpu die and the copper core and reinstalled the HSF with atric silver. It's a little cooler now at a steady 55 degrees. This is no where near the 41 degrees I origionally had. Anyone have any suggestions? I've never had a CPU react to OCing like this before...
Specs:
1.2Mhz AMD TB 266mhz FSB
2 @ 256MBs PC2100
Shuttle AK31v3
Gainward Ti200 128MB
2 @ 40GB Maxtor 7200rpms
Lite-On CDRW
Linksys NC100 Ethernet card
300Wt PSU
Specs:
2 @ 256MBs PC2100
Shuttle AK31v3
Lite-On CDRW
300Wt PSU
