Hi,
I have a desktop pc custom. Running windows 11. 23h2.
I have a core I7 8700k 3.70 GZ. Overclocked to 5.
I have a Gigabyte Z370 Aorus gaming 7 board socket 1151. I'm running this for an overclock
View: https://www.youtube.com/watch?v=mcZkEZ8x3oA&t=162s
Now what happens is when I go to run videos weather it be through youtube or facebook or anywhere online. On Ocassion meaning that days go by and it will be fine.
Then all of a sudden I will get this buzzing noise when I'm running a video. And my whole computer will be locked up.
I will have to restart my computer and that fixes it but only temperaraly. Not sure if its coil wine.
I didn't want to go into the bios and reset the bios to factory defaults. Or optimized defaults until I checked with you. It only happens when I run video. And like I said it might be 2 or 3 days and it will happen again. I only have the processor Overclocked. Not the memory.
I also Bought 2 external fans that are sitting on top of my mid tower coolmaster case. Covering the 2 vents on the top of the case. So I just have 1 usb plugged into the back not sure if it's a 2 or a 3.0 port. And they both run at the same time.
I had the fan speed for both set to high and then I saw that wasn't working for the issue. So I went to medium where I'am now.
I thought this might be a sound issue and I was running an older driver from 2017 for my Onboard realtek sound. so I have the Software called Driver Booster. and I downloaded updated drivers for my realtek. The Publisher is realtek. But maybe the ones from Gigabyte would be more compatable. And would fix this issue I'm not sure.
In the power managment settings. In the control panel. I have The power scheme set to Power saver. Turn off the display set to never. Put the computer to sleep Never. Turn off hard disks Never. Or set to zero.
Sleep after never. Allow wake timers disabled. Usb Selective Suspend Setting Disabled.
Link State Power Managment. Maximum Power savings. Under Pcie.
Processor Power Managment. Minimum State 5%. Maximum State 75%. Lowered from 100%.
Turn off display after. Never. Wireless Adapter Settings. Maximum Power Savings.
When Sharing Media. Prevent Idling To Sleep. Video Playback Quality Bias. Video Playback Power Saving Bias. When Playing video. Optimize Video Quality. I have GSYNC turned on in my Nvidia control panel I have the latest drivers of 2021 for my
LG HDR 4K(Display Port). I have Scaling turned on. Set to Aspect Ratio 16:9.
Manage 3d settings
I have Image scaling off. Ambient Acclusion Off. Anisotropic Filtering Application Controlled.
Antialliasing FXAA. OFF. Antialliasing Gamma Correction. I have On. Antialliasing Mode. Application Controlled. Antialliasing Transparency. I have Off. Background Application Max Frame Rate. Is OFF. Cuida GPU'S. ALL. Cuida System Fallback Policy. Driver default. Dsr Factors OFF. Low Latency mode. Ultra. Max Frame rate. OFF.
Monitor Technology. G-Sync Compatable. Multi Framed Sampled AA. OFF. Open GL GDI Compatability. Auto. OpenGL Rendering GPU. Auto Select. Power Managment Mode. Adaptive.
Shader Cache Size. Driver Default. Texture Filtering Anisotropic Sample Opti. OFF.
Texture Filtering Negative LOD Bias. Allow. Texture Filtering Quality. Quality. Texture Filtering Trillinear Optimization. ON. Threaded Optimization. AUTO. Tripple Buffering. OFF.
Vertical Sync. Use The 3D Application Setting. Virtual Pre Rendered Frames. Set to 1.
Vulkan Open/GL Present Method. Auto.
Configure Surround Physx. Processor set to . Nvidia Geforce GTX 1050. Change Resolution. 3840x2160 Native at 60 HZ. Use Nvidia Colo0r Settings. Color Depth for Desktop. Highest 32 Bit.
Output Color Depth 10 BPC. OutPut Color Format. RGB. Output Dynamic Range. Full.
Adjust Desktop Size And Position
Scailing Mode. Aspect Ratio. Perform Scailing on. Display. Override The Scailing Mode Set By Games And Programs. Has a check in it. 3840x2160 Resolution. 60HZ.
Set Up G-SYNC.
Enable G-Sync Compatable. Checked. Enable For Full Screen Mode has a dot in it.
Display Specific Settings.
Enable Settings For The Selected Display Model. Checked. Selected display is not Validated As G-Sync Compatable. Adjust Video Color Settings. With the Nvidia settings. Is what I have it set too.
Adjust Video Image Settings.
Edge Enhancment. Use the Nvidia Setting. Use Inverse Telecine. Deinterlacing.
Noise Reduction. Use The Nvidia Setting. Use the adavnced 3d Image Settings. I don't run Games. I'm not a gamer.
Hardware Accelerated Gpu Scheduling Is off in the display settings of Windows. Variable Refresh Rate is Off. Optimized for Windowed Games Is Also Off. Use Hdr is Off. And I'm not using Multiple Displays.
Should I take the video card out of my system and clean it? Just use duster cleaner or something Like that? Maybe that might help. I'm not overclocking the video at all. My Case is in a door Compartment at the bottom left of my desk but I have the door open. As well as the fans I spoke about earlier.
Any help would be much appreciated!!
Manage 3d settings
Set Up G-SYNC.
