OCCT 32 bit and 64 bit
salm2s
266
6
10,815
Hi there,
I did a occt test on my 7600k @4.5 ghz, with a voltage of 1.3. When i do the 64 bit test, it does not work, but when i do the 32 bit test, it works fine.
Is there something wrong?
A failing core makes me think that your overclock is unstable. I would make sure you xmp profile is selected in the bios. Then tweak the oc to see if it helps.
Are you on at least DirectX 10? I know the 64 bit stress tests are ram heavy. You might download and run memtest86.
I have ran memtest86 before and i had no errors. Even when i clocked it down 100mhz it still didnt work. And this was using the bios preset
