Question Oc'ing crucial ballistix sport lt 2x4 2666mhz OC-2866 to 2933mhz with stock cooler?
Sep 6, 2019
8
so i have this ryzen 5 2400g
and crucial ballistix sport lt 2x4 2666mhz OC to 2866 with timings 16 18 18 38 35
is it ok/safe for me to OC the ram to 2933mhz with the stock cooler?
i will appreciate the help.
DMAN999
Respectable
Apr 17, 2019
1,765
443
1,890
65
If you got them to 2866 MHz, you can certainly try for 2933 Mhz.
But IMO you won't see any noticeable difference between 2866 and 2933.
I had some Patriot Viper Elite 2666 MHz RAM that I OC'd to 2866 MHz (with tighter timings) and they were 100% stable.
I did get them to 2933 but they were not 100% stable and the performance difference wasn't noticeable except in a Memory benchmark.
So my advice is to stick with 2866 MHz if it is 100% stable.
Sep 6, 2019
8
I had some Patriot Viper Elite 2666 MHz RAM that I OC'd to 2866 Hz and they were 100% stable.
Ok bruh thanks guess ill just stick to 2866 for stability :)
DMAN999
Respectable
Apr 17, 2019
1,765
443
1,890
65
I have the same memory but 2x8gb 2666mhz.I got it running at 2933mhz stable but......It doesn't like when i tighten the timings :p
That was the same issue I had with the Viper Elite kit.
They would run at 2933 but if I tightened up the timings even slightly they wouldn't boot.
And to get they stable I had to loosen the timings way up which was why they didn't perform any better than at 2866 with tighter timings.
