OCing E6600, Stuck At 375Mhz! What????!!!
slim142
2,704
Hi
My system is the following:
ASUS Striker extreme
Intel E6600
Corsair TWIN2X1024C4 1GB DDR800
eVGA 7900GS KO HDCP
Zalman 9700LED
Seagate barracuda 7200.10
Maxtor Max Line Pro 500gb
Audigy 2 ZS
My BIOS settings are configured like this...
AI Tuning: Manual
Nvidia GPU Ex: Enabled
LinkBoost: Disabled
SLI-Ready Memory: Expert
FSB - Memory Clock Mode: Unlinked
FSB - Memory Raio: N/A
FSB (QDR), Mhz: 1333 (means 333 mhz FSB)
Actual FSB (QDR), Mhz: 1333
MEM (DDR), Mhz: 815 (means 407 mhz speeds)
Actual MEM (DDR), Mhz: 815
Bios version: 1002 BETA
Multiplier: 9
Vcore Voltage: 1.47500 in BIOS (1.44 in Probe II)
Memory Voltage: 2.1v
1.2v HT Voltage: 1.25 (1.30 in Probe II)
NB Core Voltage: 1.40 (1.44 in Probe II)
SB Core Voltage: 1.50 (1.52 In Probe II)
CPU VTT Voltage: 1.25 (1.30 In Probe II)
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
tCL (CAS Latency): 4
tRCD: 4
tRP: 4
tRAS: 12
Command Per Clock (CMD): 2T
Advance Memory Settings
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Enabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 100
PCIEX16_2 Frequency (Mhz): 100
PCIEX16_3 Frequency (Mhz): 100
SPP<->MCP Ref Clock, Mhz: 200
This is stable at Orthos for 8 hours, Didnt run any longer cause I think with 8 hours is enough to probe is stable. I can go as high as 1500Mhz FSB (375mhz) and voltage have to be raised up to 1.45000 (1.42 in Probe II) so it can boot. It wont run orthos for more than 5 minutes. Tried raising NB voltage, VTT and 1.2 but nothing. No matter what I do it wont be stable (Some people even have their E6600 at 400mhz at 1.40vcore)
Also I thought it was some bad FSB spot, tried to bot at 1510, 1520 and 1540 and nothing, black screen. Even 1480 wouldnt be stable at orthos.
As you can see my memory is at 815mhz, That is 100% stable tested with memtest86 1.70 so that is not a problem (even thought is only 15mhz OC, I will go further but I want to OC the CPU first)
Does anybody know what can be happening? I really want to achieve 400Mhz. Please Help me out OC experts!
you got the quad core bug! 1333 max for striker!
my stiker says cpu-int and asus says rma! how to i enter rma into the lcd screen.
memory is swithching back and forth as the auto contols even out everything ---manually set it all thats why its not stable
you might want more mem voltage if its cool - 2.15-2.2v at your speeds
set your voltage nb to 3rd setting,
turn off all that auto stuff and manually set it pc-x =100, etc
turn off non essential controllers and usb boot
cpu voltage should be 1.4-1.45 stck cooler is ok for 3.2-2.5ghz - thermal-right is better idea. 1.41 will read 1.38 or so and get you 3.2ghz +/- .1ghz
or 1.55-165 for extreme oc with a good after market cooler - cpu's are cheap - it still last 3-5 yrs if you keep it under 70c
nb = 1.57 or what ever the third highest is
mem = 2.1 v or more with good ram
set all latencies manual - if you have ddr800 set ram to 650-750 then set latencies then set speed - check the ram is hot? if not turn up the voltage
intel is #1 - no flaming!
