Hi All,
I am planning to purchase an E8500 to overclock to 3.6 GHz using the 9x multiplier and 400 MHz (if there is a better calculation in your opinion, let me know, I'm kind of a nub at OCing). There is only one problem... Due to the nature of my case's fan layout, my Heatsink/Fan can't exceed 120mm by very much if at all in "Heatsink Height", or how much it "pops out" from the motherboard. The best one I have found so far in this size is the Ninja Mini, but it is about a year old in reviews.
Will the Scythe Ninja Mini work well enough to safely OC at 3.6 GHz E8500? I have heard many people can get this setting without touching the default voltage much, if at all. Does anyone think Stock Cooling would be better? Also do you think the ASUS P5Q-Pro will provide enough clearance for RAM using the Scythe Ninja Mini?
Does anyone know a better HS/F solution in this size limit?
A link to the Mini:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185046
Link to Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
Link to Processor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Link to some test results, it seemed to keep up with the Thermalright Ultra-120 pretty well.
http://www.3dgameman.com/content/view/10463/36/1/8/
I really only plan to OC this chip mildly, 3.6 GHz is fast enough for me (a jump from 3.16GHz stock on E8500), and in many cases I have seen on the net the default voltage works with a ~450 MHz+ OC.
Also who thinks stock cooling would work? I don't mind fan noise at all, so is there a way to keep the fan at 100% all the time and just keep stock cooling if I won't be increasing voltage much/at all and if I can safely 24/7 using this OC with stock cooling?
I would be using Arctic Silver 5 in any instance, so I suppose that would improve over stock in the first place right?
A link to the Mini:
Link to Mobo:
Link to Processor:
