hi there i built a new machine
ASUS P5Q
E8400
XFX GEFORCE 9600 GT XXX EDITION
2X1G KINGSTONE HYPERX 1066
the problem occurs when i start overclocking when i play a game it crashes and stop responding and a blue screen sometimes and restart or it crashes only without blue screen ( i tested the oc"ing with prime95 for 5 hours without errors and the problem occurs with games only and gpu temp idle 57 and in load 70 i think it isn't too much where the problem comes from i tried all settings and i'm now very confused
i'm using this settings
AI twicker menu; settings
Ai overclocker tuner.............manual
COU ratio.............................9.0
FSB freq...............................400
PCIE freq.............................100
FSB strap NB........................auto
DRAM freq...........................1066MHz
DRAM timing.........................auto
DRAM static read..................disabled
DRAM read training..............disabled
Mem. OC charger.................auto
AI clock twister....................auto
AI transaction booster.........auto
CPU volt...............................1.26250
CPU PLL volt........................1.5
FSB term volt.......................1.2
DRAM volt............................2.2
NB volt.................................1.1
SB voltage...........................auto
PCIE SATA............................auto
load line calibration..............enabled
CPU spread..........................disabled
PCIE spread.........................disabled
advanced menu settings;
C1E support.........................disabled
Max CPUID value limit..........disabled
Intel vurtualization...............enabled
CPU TM.................................enabled
execute disable BIT..............enabled
ASUS P5Q
E8400
