So I know the PSVR is listed to have an 100 degree of FOV while the Rift and Vive is 110 however those are not necessarily true or exact....
My question is on your experience what one has the better FOV (Non modded "Stock") I use the PSVR adjusted to be as close to my face as possible using the Glasses "Slider Adjuster" and I see probably about 105 degrees of view... is the Rift about the same or is it more?
I do know the PSVR has about your entire vision vertically if you do not move your eyes however horizontally is definitely way lower since you see the black if you are not fully immersed in the game.
