Hi,
I have an Asus laptop and the power jack was faulty, the battery would stop charging until I wiggled the connector, so I ordered a new one and replaced it, this is something I have done before and my soldering skills are decent, not an expert but not a beginner either.
I have removed hundreds of laptop motherboards before and never damaged one before
When I removed the old power jack the centre pin fell out, there was a clean break in it so that was definitely the problem.
After replacing the jack the laptop powers on with the power connected every single time now, so that is all good
BUT.......
with the power connected when Windows loads it shows "battery not detected", I unplug the power and it then shows 100% and it never decreases
With the power unplugged I can restart the laptop OK but if I shut down I can not power the laptop on again from battery power. The laptop will only power on if the power is connected.
I have tried a new battery but no different
I have installed Windows on a different SSD with the same results
Any ideas on what could be the issue?
Thanks
BUT.......
Thanks
