I put one thermal sensor on the chipset and its temp reading (by MBM5) is higher than that of cpu! I always thought that chipset is cooler than cpu. May be I'm wrong all the time =(
To be more precise, I put one thermal sensor on the HS (as close as the cpu and right above the cpu) and get about 40-41C at full cpu load. Plus about 5C to that to approx the real cpu temp so end up about 45-46C. But the chipset temp is max at 43C!. I always thought that the chipset temp should be lower than 40C ??? Any explanation would be greatly appreciate =)
P.S. The cpu is actually max out at around 46C(reading) + 5C(correction) ~ 51C when I play a lot of games continuously (more than 2 hours straight). All temps are measured with closed case.
AMD Athlon T-1.2G
MK33 AOpen, Via KT133
320MB 100MHz SDRAM
Seagate 8GB
ATI Radeon 64 DDR VIVO
1 CD-ROM
1 CD-RW
1 Floppy Drive
10/100 mbps Network Adapter
250W PSU
AMD Athlon T-1.2G
320MB 100MHz SDRAM
Seagate 8GB
1 CD-ROM
1 CD-RW
1 Floppy Drive
250W PSU
