[SOLVED] Odd cooling setup need help
rockysealyjr
41
I am working on building me my 3rd and most powerful computer. I am planning on custom cooling my pc. It is very hard to explain how I am trying to cool it so I made this in microsoft paint. Can you guys make any suggestions about it and possibly even link me to some parts that would do well. I am looking at EK's pump/reservoir EK-XRES 140. But I'm not sure if the pump is strong enough to push the liquid through the system. I am using dual 360mm radiators (I like to be overkill)
Thanks
https://cdn.discordapp.com/attachments/439148114801065996/597800752399908864/Untitled.png
Reservoir/Pump -> CPU block -> 360mm Radiator -> GPU block -> 360mm radiator -> Back to Reservoir/Pump
Fairly standard, order doesn't really matter. It is a bit overkill, even without knowing the CPU and GPU in question.
D5 pumps can handle more than that...You could safely toss in another radiator and GPU and not worry about flow restriction.
My build for comparison.
7700k at 5Ghz + 1x280mm XSPC radiators + GTX1080 XSPC Razor full coverage waterblock, and a DDC based Swiftech H240X (280mm)(the old one) More than enough for that loop, and the DDC is nowhere near as powerful as a D5.
