Question Odd DRIVER_POWER_STATE_FAILURE on startup, but fine after restart
Jan 16, 2021
Hi everyone,
For some context, I did a clean install of Windows about 3 weeks ago. Just last week, my computer would run for a little bit after startup then hit me with a "DRIVER_POWER_STATE_FAILURE" BSOD. After Windows automatically restarts from there, I can use my PC fine without any issues. The only annoying thing is that it happens every time I turn on my computer or wake it up from sleep.
Now, I haven't really installed any drivers that could be causing this issue. The only thing I've really done was plug in my USB Xbox controller (more on it later) and I also had an overclock on my GPU (maybe a little too much?) that I have since disabled, but I don't know if that is what's wrong. My BIOS is up to date and I don't want to go about messing around with every installed driver, guessing and checking to solve the issue. My main concern is pinpointing the exact driver that's giving me issues.
I'm going to attach some relevant information that might help solve this issue.
Crash description from Event Viewer:
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000009f (0x0000000000000003, 0xffffc8842d9af8f0, 0xfffff8017786d750, 0xffffc88433f9db20). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 30e04ef6-d456-404d-9728-54ef520859b3.
BlueScreenViewer (I started by analyzing the crashes that were happening, then got some interesting results when I ran Driver Verifier, more on that later):
View: https://imgur.com/a/HMdR25z
Going through some dumps, it appears that xusb22.sys or something to do with an Xbox controller is giving me issues. I can upload more dumps later but what's the immediate cause of this issue? Should I uninstall the driver for now?
Much thanks in advance.
If this helps:
  • Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: ffffdd0c6ded0cd0, Physical Device Object of the stack
Arg3: ffffef8d0283f750, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffdd0c6fa4d4e0, The blocked IRP
Debugging Details:
*** WARNING: Unable to verify checksum for win32k.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 5108
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on DANSPC
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.mSec
Value: 13036
Key : Analysis.Memory.CommitPeak.Mb
Value: 83
Key : Analysis.System
Value: CreateObject
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
ADDITIONAL_XML: 1
OS_BUILD_LAYERS: 1
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffdd0c6ded0cd0
BUGCHECK_P3: ffffef8d0283f750
BUGCHECK_P4: ffffdd0c6fa4d4e0
DRVPOWERSTATE_SUBCODE: 3
DRIVER_OBJECT: ffffdd0c6b97dba0
IMAGE_NAME: xusb22.sys
MODULE_NAME: xusb22
FAULTING_MODULE: fffff80133540000 xusb22
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffffef8d0283f718 fffff8012e15f297 : 000000000000009f 0000000000000003 ffffdd0c6ded0cd0 ffffef8d0283f750 : nt!KeBugCheckEx
ffffef8d0283f720 fffff8012e15f1b1 : ffffdd0c6f8e32a8 ffffef8d0283f878 0000000000000000 ffffdd0c6a068ac8 : nt!PopIrpWatchdogBugcheck+0xdf
ffffef8d0283f790 fffff8012de44f12 : ffffdd0c6f8e32e0 ffff8b00c01e8180 ffffef8d0283fa18 ffffdd0c00000002 : nt!PopIrpWatchdog+0x31
ffffef8d0283f7e0 fffff8012de06eed : 0000000000000000 0000000000000000 0000000000140001 00000000001e840c : nt!KiProcessExpiredTimerList+0x172
ffffef8d0283f8d0 fffff8012dff92ee : 0000000000000000 ffff8b00c01e8180 ffff8b00c01f3240 ffffdd0c6ee37080 : nt!KiRetireDpcList+0x5dd
ffffef8d0283fb60 0000000000000000 : ffffef8d02840000 ffffef8d02839000 0000000000000000 0000000000000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION: 10.0.19041.208
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x9F_3_IMAGE_xusb22.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {b809f1f3-d516-d278-4cf4-f0faeccdd54d}
