Hi!
Today I got my friends computer in for fixing. Let me explain: when you turn on the computer ethernet doesnt work until you replug the cable a dozen times(then it lights up) sounds like pc is turning of ethernet. Friend already tried an ethernet card a new tp link one... Same issue. I tried to reinstall windows, change all drivers, checked bios and reenter dnses and ips manually... Still thr same issue.
Any ideas?
Thanks in Advance!
EDIT: Solution
Even when I changed the router issue continued... Because I have 3 more pcs on the same network and they all have a static ip there was an ip conflict... I simply assigned a new static ip to the pc(on the router AND on pc) and it worked!
Thanks for all the help!
Any ideas?
Thanks in Advance!
EDIT: Solution
