Hi
I have a rather strange situation where I am no longer able to connect to wireless internet.
I use the free internet from the shop downstairs, I had permission to use it as does the rest of the house.
The strange thing is that since my Wifi went down yesterday, I have noticed its also disabled on my smart phone too.
The notification says that there is limited or no connectivity and a normal repair only prompts that my PC cannot renew its IP address
So I tried to renew and re list the IP setting, flush the DNS, recatalogue etc and still no joy. I have re installed my PCi adapter twice and even used a different card, pulled them out and cleaned the PCi slot...basic housekeeping
An ipconfig command at the command line shows that the IP address isnt your standard 192.168. xx type ...(its something like 165.0.01)...the subnet is normal 255.255.xx
A look at the status window in attempt to manually input an IP address instead of the automatic function shows that there is no default gateway...just the odd IP address found when I did ipconfig.
Ive also tried a winsock repair..no joy..also I have checked the services.msc and made sure all the relative services are enabled and automatically set.
An attempt to connect to a different network ( my smart phones 3g hotspot and also my neighbors wifi) both were successful...so I dont see the problem to be with my PCi adapter......but then again I dont think its the shops router either, as both of my housemates can use the internet on their phones??..they are not tech savvy at all and would defiantly remember if they had recently changed anything or lost the service...usually its me who has to set up their computers or smartphones and they would be banging on my door if they lost the service also!
Im unsure if a wrong WPA 2 key would show up as a "limited or no connectivity" notification??..surely it would just say that the key was wrong?
im lost...any ideas
many thanks
Martyn
im lost...any ideas
many thanks
Martyn
