[SOLVED] OEM Motherboard Ram help
Nov 8, 2020
8
Hello!
My motherboard is a HP Sunflower 8433. (https://support.hp.com/au-en/document/c05939208)
I was looking to install 16GB of ram and wasn't sure if it would work on my system.
I am using a 64 bit OS
and was looking to buy this https://www.pccasegear.com/products/47019/g-skill-flare-x-16gb-2x8gb-3200mhz-cl16-ddr4
I know this is a 3200mhz and my motherboard says it can have 2400mhz but I herd someone say that the ram can downclock to 2400mhz.
Also this ram kit says it works on ryzen processers so I think this is suitable for my motherboard.
Please verify if it would work.
Thanks!
The HP website actually lists on the site you linked what is supported:
  • Dual channel (2 DIMMs per channel) memory architecture
  • Two DDR4 UDIMM (288-pin) sockets
  • Supports PC4-19200 (DRR4-2400)
  • Supports 4 GB and 8 GB DDR4 UDIMMs
  • Supports up to 4 GB on 32-bit systems
  • Supports up to 32 GB (unbuffered) on 64-bit computers
The important part for your question is, that it supports 8 GB sticks.
