OEM /Upgrade OS Product key issue
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I installed XP upgrade to WIN 98 on dual boot computer. Then XP crashed. The
only way I could repair it was to use my OEM XP full version CD. Now I don't
have the Upgrade Key on this computer. How do I get the correct key back so
that I can re-activate this OS?
You need to locate the key that came with that CD.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar/
"DiNet" <DiNet@discussions.microsoft.com> wrote in message
news:302017F4-D52E-4DB0-BD20-7EAD8FC657AD@microsoft.com...
>crashed. The
> I don't
> back so
If you are telling the truth that you did buy it , then
call microsoft or the place where you did purchase it
from ... but if you copy it from someone , no one is
going to give keys out
>-----Original Message-----
correct key back so
What exactly happened when you tried using your Windows XP Upgrade CD to do
the repair?
If your CD is damaged contact Microsoft here
http://support.microsoft.com/default.aspx?scid=KB;en-us;326246 [bottom of
the page]
Harry Ohrn MS-MVP [Shell/User]
www.webtree.ca/windowsxp
>The
> don't
> so
I should have mentioned that an XP Upgrade CD Key is not compatible with an
OEM CD so if you used an OEM version of XP to install overtop of your
current setup you won't be able to use an Upgrade CD with it.
>The
> don't
> so
Product Keys are bound to the specific type and language of
CD/license (OEM, Volume, retail, full, or Upgrade) with which they are
purchased. For example, a WinXP Home OEM Product Key won't work for
any retail version of WinXP Home, or for any version of WinXP Pro, and
vice versa. An upgrade's Product Key cannot be used with a full
version CD, and vice versa. An OEM Product Key will not work to
install a retail product. An Italian Product Key will not work with
an English CD. Bottom line: Product Keys and CD types cannot be
mixed & matched.
You need to use your _legitimate_ l retail Upgrade copy of WinXP
Pro to perform a repair (a.k.a. in-place upgrade) installation, using
its CD and Product Key.
How to Perform an In-Place Upgrade of Windows XP
http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q315341
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having both at once. - RAH
>crashed. The
> I don't
> back so
